I need to remove the silver spray paint that covers the upper plastic body of the hustler I just bought. Any suggestions?
Upper Body Paint Removal
a good steamer will probably lift it with tip dead against the plastic moving in small circles. I had good results on my Buffalo. it depends on how well it was prepared and quality of paint used. If you already have some peeling, it will probably work.
Originally posted by ColoradoDave View PostI need to remove the silver spray paint that covers the upper plastic body of the hustler I just bought. Any suggestions?Acta non verba
It was painted silver to try and make it look good to sell. It is a fresh coat of silver spray paint. It's not oxidation, although I wish it was. I tried lacquer thinner and mineral spirts and neither worked well. The rubbing did put a lot of static electricity into the body. I guess I will go to an automotive paint store and ask them what they think. Maybe I will just have to paint over it.
I removed the paint of my attex with old brakefluid. test on a unimportant piont and if it is ok then paint the brakefluid thin over the color and wait a day. there will be a lot of blisters the next day and the paint will be like rubber and you can scratch it of the vehicle.
