This is the split shifter mechanism that I built for my hustler.It is a cable operated break apart that uses the original shift lever and incorporates a means to alternate from shifting both sides at once or one side at a time.
Hustler split shifter pics
This is gonna take some time so you might want to go to the bathroom,grab yourself a beer (or two)or (in my case)a cup of coffee OK.Everybody ready? Here we go:first pic The cable at the top is attached to a yoke (the angle shaped piece)the yoke is pivotally anchored at its bottom,to the upright which supports the stock shift linkage crossbar and works similar to the throwout bearing yoke in a standard shift auto tranny.By pulling a lever at the other end of the cable,the yoke pulls the tube (left side of pic 2)which is welded to the locking disk (right side pic 2),this compresses the spring and allows the 2 halves of the locking disc to seperate (shown open in pic 2 shown closed in pic 3 )and move independently,each from the other.The right half of the disc shown in pic 2 has 6 holes (2 for each position)drilled through it,the left half has 2 pins in it which align with the holes in each respective position Pic 4 is the entire mechanism.To shift from forward to reverse you simply shift as usual.This mechanism is left side (tranny)oriented so whatever direction you split shift from the left side will stay in that gear.Example: you are in forward and want to zero turn to the left;stop the machine,shift to reverse then pull the cable and move the shifter to forward,release the cable to lock the disc,you now have the left side in reverse and the right side in forward push the right stick forward , pull the left stick back and make your turn.When you complete the turn and stop movement,simply pull the cable to unlock the disc;return the shifter to reverse and release the cable:the disc is now locked in normal shift position and will shift both sides of the tranny at the same time.To shift the other way is similar.Hope this helps.Would I recommend this to anyone else ?Not necessarily.It is complicated to lay out and build,and not nearly as straightforward as just installing a seperate shift lever for the other side.But I didn't want the other lever in the way in an already crowded space.-GreggDESTRUCTION is just a couple of vowels down the street from DISTRACTION
*feeling dizzy*......
nice, yet confusing.....for a simpleton like me anyway.
I didn't know you could put each side of the tranny in a different direction, if, that is what you are describing?
Very cool if so........
So, the trans direction is independent, left and right?
Thanks, as confused as I am..........
HenryHenry:
You think it's confusing to read,try writing a description of how to the thing works.WOW! But it's a lot easier to use than it sounds.As with anything,the really tough part was building the first one,after that it's only a matter of duplicating what you have already done and refining what needs to be changed.For example the locking disc could just as easily be made using two round platesof 1/4"steel.
Yes that is one advantage of using the T-20 transmission,it can be shifted each side independently of the other with a modified factory shifter.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
