I'm replacing the belt on my Hustler 900 with the Kohler 440 2 stroke. I'm trying to decide if this machine was poorly designed or I have a larger diameter secondary (driven) clutch than stock? The frame is notched out to clear the secondary, and there is no room to slide the belt between the frame and the clutch. You need to unbolt the transmission and pick it up a bit to get the belt off. There isn't enough space to remove the clutch it hits the tub, and it won't slide far enough to get the belt to clear the frame.
The belt barely fits between the primary clutch and the body.
Is this how they all are, or am I not seeing the easy way to do this?
Thanks
If I'm not explaining it well, let me know. I can get some pics up if that will help.
Thanks
