is there any website i can pull up the schamatics up on a hustler i have no clue how to work on these machines and im tryin to get mine goin
manual
I have a pdf of a hustler manual if you PM me your email I'll send it to you. In the mean time could you describe your machine a little bit so everyone can figure out what Hustler you have:
2 (snowmobile type engine) or 4 stroke?
what size tires?
what is the body made of fiberglass or HDPE plastic?
Mike"Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
motor
its a two stroke two cylinder kohler motor and my body is plastic and whatever tires i should have on it i have no idea about these machines tryin to get into it the air cleaner cover says hustler and model number 960-hk and serial number 875-119799
Hey guys I tried emailing it but the pdf is too large. However we have the brouchure and manual posted here on the site
Mike
Here is a link where you can download the kohler 2 stroke manual it's toward the bottom
Kohler ManualsLast edited by micmac; 04-06-2009, 06:22 PM."Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
your best place to look is right here.. with the manuals that are archived in the articles section and the reading in the forums and galleries, you should have no problems figuring things out. If you do run into a major problem, again here is the best place to look...there are plenty of seasoned riders/restorers here to offer guidance, advice, and encouragement...so don't be scared we will all try to help....
