As promised here are a few pics of the 950 with the Mudbugs. When I was doing the restoration on my Hustler I was told that a 22" tire was the biggest tire that I would be able to run on it. It seemed to me that I had enough room to fit a larger tire, Dave (Mudbug3+) had access to a couple of them that were already mounted on rims and we tried them on for size. I only had to space them out about 1/2" and have now been running them for about 4 months. I have noticed that they are harder to skid steer due to their superior (compared to the rawhides) traction.--Enjoy!
Here's proof: 25" Mudbugs on 950 Hustler
You betcha Kahn! Matter of fact, the best service I ever got out of the rawhideIII's was when I traded them to Matt O for 6 of his
9" Beadlock rims. There is no comparrison in performance, and I reaffirm this fact EVERY time I ride through stuff with the Mudbugs that I had to winch out of with the III's. Come to think of it, I can't recall a single time that I've had to winch out of a hole that the rawhides had me pulling cable to get unhung from. In the close-up shot of the tire, you can see a chunk of bark stuck between the rim and tire, with the original rims and III's that would have been a flat and likely a popped bead, even at 4psi. What this pic shows is a tire that is still seated on the rim and holding air at only 1psi inflation. If I had a guage that would read in 1/2psi increments, I would try that because I like to watch them wrinkle up when they roll over something!
Well I knew someone would get around to asking that, and to be honest I have never put them to the GPS test. But I can say that the III's had 0 water speed, 0 control and 0 muddin ability. Whereas tha' Bugs at least will swim enough to allow me to move and maneuver in the water, with the treads in their intended orientation. Which also gives superior traction and pulling power, and also crawls over logs better. I recently took a minute to voice my OPINION of III's on the other site. I think it says it all.
My link wouldn't connect, but if you want to read go to Route 6x6 discussion board and look up "tire tread height", under "shop talk". My replies are under Gregg GLast edited by brushcutter; 06-06-2009, 07:47 PM.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
SWAMP HAWG ,
( brushcutter --> QUOTE ) " I actually call them rawhides, after running them for only 3 months I came to call them Redasses. I would say go with something larger and more aggressive, but I don't know for sure that the '99 Max will have enough tub clearance. Now as for why in my opinion they (can only speak for the 22's)are JUNK is as follows: They have almost no mudding ability compared to some other tires ( vampires or terra tires,I run 25" Mudbugs)I ride in sloughs that are full of layered leaves and silt with logs. I have driven through and over stuff that the (I'll be nice) rawhides wouldn't and couldn't even begin to go through. With the rawhides at 3psi, I was constantly popping beads loose, with the Mudbugs at 1psi I have yet to pop a bead and the ride is better than the rawhides, and did I mention they are 6 ply that means way fewer punctures- rawhides 1 hole, 1 cut in sidewall and 4 popped beads- Mudbugs 0, 0 and 0. The Mudbugs swim better for me-and I have witnesses to this- than those other tires, and yes I tried every tread direction & mix up that you can think of with almost 0 change and 0 waterspeed. Now don't get me wrong I'm not saying that the Mudbugs are gonna break any swimming records, but I will say that now I can at least MOVE in deep water, whereas with those favorites of yours all I did was stir up the water and went nowhere. I tried low throttle, high, wide screaming open, no throttle, just above idle, high idle, leaning in- every direction- rocking, back and forth all for no gain in waterspeed. If it takes all that then you just as well be on a quad. But I'll tell you the few things that did help the w/s thing-- pushing with a stick-- pulling on limbs that I could reach--winching--or just saying to hell with it and getting out and pushing. I don't know what you ride in-the city park maybe- but if you ever get into the kind of stuff I ride in, you will be needing some tires other than rawhides, unless you like winching.
Now if you want I can get a couple of other fellows to come tell you about Vampires and some other tires. "
The is the post from the Route 6x6 forum that Gregg is referring toLast edited by mudbug3; 06-09-2009, 09:03 PM.
Kooooolllll!!!!!
Thats a real good looking machine! I should get my first beadlocks this saturday when we go to CAW. I think I am going to leave my Avenger stock for now, but My T-Jet project will probably sport the Vampires or something simular.
Still want a KID
Originally posted by mudbug3 View PostSWAMP HAWG ,
( QUOTE ) " I actually call them rawhides, after running them for only 3 months I came to call them Redasses. I would say go with something larger and more aggressive, but I don't know for sure that the '99 Max will have enough tub clearance. Now as for why in my opinion they (can only speak for the 22's)are JUNK is as follows: They have almost no mudding ability compared to some other tires ( vampires or terra tires,I run 25" Mudbugs)I ride in sloughs that are full of layered leaves and silt with logs. I have driven through and over stuff that the (I'll be nice) rawhides wouldn't and couldn't even begin to go through. With the rawhides at 3psi, I was constantly popping beads loose, with the Mudbugs at 1psi I have yet to pop a bead and the ride is better than the rawhides, and did I mention they are 6 ply that means way fewer punctures- rawhides 1 hole, 1 cut in sidewall and 4 popped beads- Mudbugs 0, 0 and 0. The Mudbugs swim better for me-and I have witnesses to this- than those other tires, and yes I tried every tread direction & mix up that you can think of with almost 0 change and 0 waterspeed. Now don't get me wrong I'm not saying that the Mudbugs are gonna break any swimming records, but I will say that now I can at least MOVE in deep water, whereas with those favorites of yours all I did was stir up the water and went nowhere. I tried low throttle, high, wide screaming open, no throttle, just above idle, high idle, leaning in- every direction- rocking, back and forth all for no gain in waterspeed. If it takes all that then you just as well be on a quad. But I'll tell you the few things that did help the w/s thing-- pushing with a stick-- pulling on limbs that I could reach--winching--or just saying to hell with it and getting out and pushing. I don't know what you ride in-the city park maybe- but if you ever get into the kind of stuff I ride in, you will be needing some tires other than rawhides, unless you like winching.
I thought they sucked 25 years ago when I replaced a set of 25 x 12 x9 III's on my BIG RED 3 wheeler with a set of "new" Vampires. No comparison.
I just have continued curiosity about the swimming abilities of the Mudbugs as I impulsively bought 6 22x12x9's when I found out that size was discontinued.
I have yet to mount them as I had other mechanical issues to work on , plus I still need to order a set of Mudoxx wheels. I would possibly unload them & get some 22 x 12.50 x9 Vamps If they were way better in the water.98 Max II Adair Tracks
96 Max II 22" Mudbugs
76 Attex (450 Tomahawk?)
Thanks JP, these tires are far better in the mud than the rawhides were, and they will swim ... a little... not gonna be setting any speed records. The best - and I can't say this enough- the best thing about this setup is the Muddox beadlock rims, I have run these tires with 0 air pressure through the same stuff that popped beads loose consistently before- with as much as 6psi. I put the rawhides on in about 1hr 45 mins, but fought to get 1 Mudbug on in 1.5 hrs, wound up getting a tire store to mount the rest, and seat the bead on the one I mounted-very scary, popped so loud I could hear it 60 yds away as I drove off to work! yikes!!!
Like I said the best service I ever got out of the Hustler rims and rawhides was trading them to Matt O for 6 of his beadlock rims!
Now I have read, and seen on vids, other members running rawhide on their machines and going through some nasty stuff, which to me is perplexing, because the 22s I ran didn't do well on my machine at all. So I can't help but wonder if 25" rawhides would have done better.
I do owe some thanks to Dave for bringing, and Noel Woods for loaning, 2 mounted Mudbugs for a test fitting, which proved to me that they would, will, and do fit.Last edited by brushcutter; 11-14-2010, 10:06 AM.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
You remember what the wheels set you back? You mentioned trading your original ones to mud ox, does that mean they offer some credit or core charge?Last edited by FarwestHustler; 11-14-2010, 08:53 PM.sigpicBecause anything less isn't really "All-Terrain"
