Hustler Chain Rollers
  • Hustler Chain Rollers
    Anyone know where or what I can use for the chain idler roller? The one that keeps the chains tight. They look to be made out of plastic.:hello....
    Chain Rollers
    I would suggest UHMU. I need to replace my rollers on my Hustler as well and this is what I had in mind using. I would think you would need a lathe to dill the center hole out so that the roller would rotate true.
    McMaster-Carr
    Somebody else could chime in on this material but it seems to me this is want Huslter used.
      Why not just a set of 4 from richards relics. There 30 bucks.
      HUSTLER 980 NOS BUILD
      HUSTLER 980 TRAIL MACHINE
      HUSTLER 950 PARTS MACHINE [
        roll u...
        were they 30 each? or for all 4?
          Hmm, newbies!
            Hmm, newbies!
            Save yourself a lot of trouble and money and avoid Richards Relics/ Route6x6. Most parts he gets directly from Recreatives and then just marks up the price. If you have a Hustler or other brand AATV you can often use Max parts. For example, you can use a Max IV throttle cable and handle on a Hustler. This is what I always do......the guys from Recreatives take good care of you and offer excellent support unlike other places out there.
            As far as the rollers go, I believe they're nylon or teflon.......most industrial supply places or bearing places will be able to hook you up with something.
              Sounds reasonable enough. It was $30 for the set of 4 and they where poly I thought. Yeah Damn Newbies
