Dirty Harry,
The problem that you,ll have in putting large tires on a Hustler 980 Bigfoot, is the distance between the middle and rear tire. The Max IV also has this very same problem too. I assume this is for weight distribution in the water when carrying a passenger in the rear seat? Since the engine is mounted in the rear of both the Hustler 980 ,and and also Max IV,, this would make sense.
The space between the middle and front tire on both machines is farther apart though. Depending on the tire size, because each brand of tire varies in diameter, a 26 inch tire will probably be the largest that you can use. I have 26 inch , Bearclaws on one Hustler Bigfoot , 26 inch, ASX,s on another one, and 26 inch , Gator,s on my third bigfoot. In my opinion ,a 26 inch tire on a Hustler Bigfoot is the best size to use for mud clearance and water speed.
