I was hoping someone could help me I just got a Hustler 6x6 that a guy just gave me out of his junk yard I brought it to the shop and put a battery to it and it runs fine it just needs a little tlc so i have broke it down to replace the chains, went thru the transmission and need to replace both bearings inside also the carb needs rebuilding the float has a small crack. Does anyone know what carbs are on these its a Briggs 18horse i cant find a number to order a kit? And where is the best place to buy the parts, bearings, axle seals, etc? Thanks in advance for any help...
Hustler question
I'd try ebay for the carb and you can call Buffalo Bearing for the bearings. (716) 874-1720. They're great folks to do business with and they have helped many 6x6World members. The outter bearings are part number HC 206-19 R3. Good luck with it."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Thanks for the info I will check.Originally posted by jpswift1 View PostI'd try ebay for the carb and you can call Buffalo Bearing for the bearings. (716) 874-1720. They're great folks to do business with and they have helped many 6x6World members. The outter bearings are part number HC 206-19 R3. Good luck with it.
