I've been wokring on my Hustler for a while and now it's mostly together. I have a question that how fast should this machine run. I has the Kohler 16 HP 4-stroke engine still very strong. T20 transmission. 4 good tires and two bad ones. these two not really carrying any load since they look normal like the others without any air in them. I can measure the speed of the drive pully and the driven pully with a optical tachometer. Please let me know at full thottle on a flat surface with 200# load, what is the Engine RPM, Transmission RPM and vehicle speed should be normally. The reason is not trying to go faster but to ensure there is no big issue such as (transmission, wrong belt, clutches, ....).
Thank you in advance.
