I'm new here but, I had a question on my hustler, the round white plastic chain tensioners are they suppose to have a regular standard bolt through them or like a smooth collared bolt, because my tensioner just has a standard bolt mith some washers and it doesn;t free spin??
hustler chain tensioners ???
Thats the way mine were on both machines I now own. I had one several years back and it was also the same. Word of advice: toss that junk and build some, unless you like constantly tightening your chains! There are several members on this site who have already done this (myself included) do a search and you should get several hits.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
I don't think that would be a good idea, but you can try it. You see, most spring loaded tensioners are designed for apps where the chain moves in one direction only. Since ours move forwards and backwards, the spring will most likely not be strong enough to withstand the force of the chain when you change direction, and therefore it will be able to slacken itself.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
Originally posted by jpswift1 View Post6x6World member boncrshr made a nice chain tensioner set up on his Hustler 950 and it works great.
Do they work? Well... after initial run in on the new chains, I quit tightening them. No need for it!
The only regret I have is that Scott didn't post pics of his BEFORE I had the frame back in my 950, so I had to pull the frame back out. BTW, this can be done w/o pulling the frame, just keep a bucket of water handy to cool the tub as you weld, and don't get things too hot. I think the existing cross members could possibly be used, but since I had already built all of mine I never checked to be sure.
Brushcutter,
Did you build the above mentioned tensioner for both the front and rear drive chains? The front looks like it would work really nice but the rear chains don't leave alot of room on my machine.1984 Hustler 980 and some other toys that won't even swim.
This is a chain tensioner that the forum member boncrshr made for his Hustler 950. Once the initial chain stretch was finished after installing the new chain,,chain adjustments afterwards were hardly needed. These custom made chain tensioners worked great. Boncrshr set the spring tension tight on the chains, but if the chains needed to move upwards, the springs would let off some tension. What was nice about these chain tensioners, is that they always kept the proper chain tension if the chain ever needed to move. Having a chain tensioner with springs, also prevents a lot of premature chain stretch. After boncrshr and I went riding all weekend, I,d have to adjust the chains on my Max IV, but he would not.
Chain tensioners pictures from friends & fun photos on webshots
These are some different chain tensioners on a another Hustler.
I had forgotten about the vids of the tensioners, but if you look at the right side of the vid screen, you can see the SCSLCASS (Super Confusing Single Lever Cable Actuated Split Shifter). It worked great but was ... well... how would I say this... Super Confusing to use.
