Guys, what should I be looking for?
With my Hustler off the ground I rotate my wheels and my front and and rear drive chains go from Very Tight to literally dragging along the bottom(at least 1" of slack from zero slack). I looked for a bent axle or sprocket but I can't spot it. I assume that with that much fluxuation in the chain tension the problem would be obvious but I can't find it.
Thanks in advance
________
Hyde Park Residence Prathumnak
Thanks in advance
________
Not so familiar with the hustler model. Are the sprockets welded to the axle and was it welded that far off center? Just curious.
But as far as I know this is a common thing, mine are the same way on both the 950 & 980
