When i pulled the t20 out because of the loose mounting bolts i didnt stop there. I decided to tear it all apart to repaint the frame check all the bearings.
I have a few questions for the more experienced here:
Rusty frame:
Pics are of frame side rails in the front have some rust and scaling. This is the worst area. Appears that water sat in the machine for some time. Should i weld some new flat steel on the inside or just sandblast and paint?
Sprockets:
Appear to be in good shape to me. Best pics i could take with camera phone. Some oblonging of the axle/sprocket holes on the center axles i believe that causes some play. Is there a trick to correct this other than replacing? Where to buy new axle to sprocket bolt from?
Axles:
None appear bent. Outter bearings in real good shape. Going to leave them in place, just clean and regrease. Is it ok to put anti-seize on the axle where the sprocket bolts on and where the inner bearing rest? Going to put silicone between the outter bearing flanges as I saw on a post here somewhere.
Sure there will be more questions. Thanks!
Rusty frame:
Sprockets:
Axles:
