Does anyone know a place where I can buy good chain for my Hustler? I've read some posts about people getting stuck with cheap chain and I want to make sure I don't.
Chain
Motion Industries has good Diamond chain. I have had Diamond chain on the Avenger since 2006. Still no stretch. Buy the good stuff and it will last you. My 2 cents.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
I have always had pretty good luck with cheap chain but man.... When a chain breaks and wraps around your axle sprocket and pushes a hole in your lower tub it sucks. That is not just an abs plastic thing either. I have seen it on poly bodies too like your hustler. If you can afford it get the good stuff.
Master links too. That is where I ran in to my problems, faulty master links.
