I am wondering if anyone has changed the size of the main drive sprocket on the center axle that is about twice the diameter of the wheel sprockets. I just cleaned my tub out today and removed the rusted in chains. I noticed there the a recess made into the bottom of the body for the bigger drive sprockets. the body has be cut through on one side of mine by the large sprocket rubbing on it. That body recess also takes away from the ground clearance. I would like to go with a smaller sprocket and then heat and mold the tub smooth to match the rest of the bottom. I suppose it would also be possible to go with smaller sprockets on all 6 drive wheels in order to maintain a usable final drive gear ratio.
it will be the challange of balancing increased top speed against lower torque and power.... thus change to bigger engine
maybe to make up for it...
