I need to completely redo the driveline in my Hustler project, I am wondering if anyone has used or sees any downside to using 1 1/2 CR solid steel for the axles. I have a 10 foot piece in my back yard that should be about enough to make all new axles with new bearings, sprockets,l chains etc. Also plan on beefing up the frame and adding some C channel or angle iron for the inner bearings that is futher away from center..
Also thinking of using smaller (less teeth) drive sprocket on the axles and lowering the axles an inch or two if possible for increased ground and body clearance. plan to run 25" tires
Oh last question is about the chain tensioners. Any reason not to use idler sprockets instead of the stock plastic bushings?
