i want to upgrade my wheels. i have 22x11x8 and a 5 bolt pattern. how do i convert to a 4 lug wheel. thanks.
hustler wheels
This is going to be a big hassle to do this. First you would have to grind all the welds off and remove the stock studs, 30 in total, 5 lugs times 6 axles. Next, you would need to weld new round steel plates onto your hubs and drill through those plates and the stock steel plates. Then you would have to buy all new studs that are long enough to go through the stock hubs and the new steel plates you welded on. In my opinion, it isn't worth that boat load of trouble to do all this."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
They have 5 lug wheels in 9" sizes......that's what Argo uses. I'd highly recommend some 25" tires for a Hustler 950. They're the largest size you can get and they make your Hustler look like a beast.
GoodYear 25x11.50-9 Rawhide III Argo Honda ATV 2 Tires - eBay (item 250631851389 end time Feb-06-11 07:26:37 PST)
Here's a pair of Goodyear Rawhide tires for $100 shipped to your door."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Yep, you should be in good shape. I know 6x6World member Jerseybigfoot put some 25" Rawhide III tires on his Hustler and they fit just fine."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Welcome to the family! There aren't too many of us with the 945-HK... As usual, jp is right on the money....Originally posted by jasonhaston View Postthanks man. mine is a 945-hk 25's should fit on mine shouldnt they. i dont see much size difference. thanks for all the help.
Much too much work, go with the argo wheels or pay for the mudox onessigpicBecause anything less isn't really "All-Terrain"
