The weather is absolute crap, and I didn't want to venture too far with something unproven by myself, but here is a hot lap around the Scanlon pole bending track. Weather is so bad I couldn't even get a GPS fix to see the speed on the pig. I'm pretty sure it's better than the 16.11 MPH with the opposed twin Briggs. It will spin all 6 tires from a standing start. Time to stock up on axle bolts!! I still have the waterproof cover on the camera, so the audio sucks, but she pretty much sounds like a Harley
Wow, Big improvement over the terra tiger you started with, lol. And 40hp
I love the end when you come back up the drive and its already all tore up!
You got to be happy!
Hard to believe how many machines have come through my shop since that Terra Tiger. I still think about that machine damn near every time I get in one. It lives a happy life in Tasmania now.
The 40 HP is a rough guess. It will go on the Dyno after Busco to see exactly where it is. Builder claims based on past engines that it should be 38 to 42, so I split the difference.
The Driveway was just getting settled back to normal from when I got the Bigfoot going in the first place. I take the box blade to it a couple times a year when it gets too rutted up
Actually, it does when you go fast in a turn, especially if you are stock & have a bench seat. I think it helps distribute the weight, however so slightly, to the inside wheels. Try doing it both ways. Fast as you can sitting erect & then leaning into the turn. You should feel a difference in control.
Brian, More HP means you have to think a lot quicker. Are you up to it?
