Shifting problem
  • Shifting problem
    Just got a used MAXX II that seams to be in great shape and runs great,The only problem is it doesn't well into forward grinds bad, but when shifting in reverse it slips right in.Any suggestions would be great. Also where is the best place to get a manual.
    Congratulations on the maxll.You may need to idle down your motor if it is idling a little high and pull the latterals back a little while shifting.You can call recreational ind.800-255-2511 give them your serial number and they can tell you the year model and help you with a manual.
      Thanks for the info
