Chain Adjustment
  • Chain Adjustment
    ok guys starting to put everything back together hopefully today. Chains will be going in first. just a quick question, how do i adjust the tension on them. Is there something in the roller where the chain falls under? mine is an older max with an actual sprocket there. or is it somewhere else. pics would also be amazing! thanks so much guys
    Brandon, if you do a search, you will find the MaxII tensioners have been discussed a lot. Here is one old thread on them http://www.6x6world.com/forums/max-a...tml#post103183
