I've been looking for one of these for a while after seeing a guy in Cincinnati make one into a tank for airsoft. He used a Max IV and fabricated a turret and full enclosure. I want to make something similar but that I can still use for trail riding. I started asking around and looked at several over priced examples before I found out a co worker had this one for $150. Its a 1985 with the Tech 16 hp engine. He said he started working on the engine and it had no spark and gave up. I got it home and parked it outside until I could get some room in the garage to start a full resto.
Yesterday I pull the upper body off, vacuumed out the leaves and gunk in the tub and set the engine off to the side. I started assessing what it needs and what it will need to be road worthy again. So far, it needs everything, lol. The frame is bent, 3 axles are slightly bent, all the bearings are bad, one drum is bent, one chain is missing, and one sprocket is bad.
Here' s a pic when I stopped last night:
The plan is to pull the axles and get the frame out. Then repair and reinforce it and give it a coat of POR15. I'll post pics as I go.
