Battery type in 96/97 Max II
  • Battery type in 96/97 Max II
    Hi All...I am wondering if anyone might know the battery type/model used in this machine? The machine is at my camp so I dont have access to l actually look at it.
    Thanks for the help!
    They take the little lawn mower type (that suck). Where are you located? I have 2 sitting on the floor of my garage, I'd give you one.
      I'm in Mass...too bad I wasn't closer! Thanks for the info. I'll pick one up..
        Hi flip, where r u in ma.? I'm in amesbury but usually ride in sanford, me. later mike
          Hi Mike... I'm about 45 minutes south of Boston in Dighton but have a camp in Garland ME where I would ride.
            The garden tractor batterie that replaces the original is a U1-L. I use the Briggs and Stratton ones at lowes. They are 300 amp and totally sealed. Have been having very good results even in the extreme cold.
              I use one of these and it has been excellent .
              I run my winch a lot pulling logs up a steep slope.
              Mine is a PC625 with 625 cranking amps.
              Check out the specs:
              Odyssey ATV Batteries
                WOW, I'm impressed, 625 cca out of a small battery...and only $106.
                I always convert to a full sized car battery to get the extra capacity....no need with one of those.
                On my first trip out with my first 6x6 (the sears sportster), I got it stuck in a ditch. I drained the tiny battery using the winch to pull it 5 feet. I decided then that the small batteries were a bad idea, and upraded.
