What's the deal with tracks for a new Max IV? Do I need the factory to do somthing with the bearings? What makes the Adair tracks better than the Max tracks?
Max IV Tracks
You want the factory to add bearing cage extensions on. The factory tracks work great in the snow and ok in mud, but swim like a rock. The adair tracks work great in mud, ok in water, and pretty good in snow. A big advantage to the adair tracks is they don't eat as much power to use like the ri rubber tracks, and the adair tracks skid a lot easier. Their biggest draw back is driving up wooden ramps that are even slightly wet.l like to buy stuff and no I don't do payments!
Originally posted by smithder View PostWhat are bearing cage extensions"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
These are cages for older maxII's with the 62mm bearings and 3 bolt flanges.
The maxIV uses a 4 bolt bearing flange, but the concept is the same. It simply puts an additional bearing farther out from the frame. I made a set for one of my machines,
and I plan on making another set for a different machine. The new set will be out of a 5" rod of UHMW PE, with a 1 1/4" hole for the axle. I'll put a seal on the inside, and just use the bearing for the outer seal. With a grease zerk in the plastic, it will act as a bearing itself, and hopefully strengthen the hollow axles enough.
To answer your other question, the axles must come out to put on the extensions.
Originally posted by smithder View PostWhat's the deal with tracks for a new Max IV? Do I need the factory to do somthing with the bearings? What makes the Adair tracks better than the Max tracks?
The Adair track kit can be used on machines with lower horsepower and do not require all the extra hardware associated with the factory track package. If you are purchasing a new machine and want the extra strength of the of the track support package you could order the machine tracked preped and add the Adair Tracks but it is not required.
The factory rubber tracks are different than the Adair tracks in that the factory rubber tracks are a closed type and the Adair tracks are open with individual grousers. I don't know that you can say one is "better" they are just different. As said previously the factory tracks are designed more for snow or mild mud use and do not propel the machine at all in water while the Adair tracks seem to work well in all conditions. You can see numerous videos here on the site of the tracks in action if you do a little poking around.
Hope this info helps, Keith.sigpic
So we have a new Max IV on order with the 29 HP Kawasaki and 26" tires. We are covered in the power department. If we wanted to later add Adair tracks all we would need is smaller tires and the tracks right? What size tires do the Adair tracks fit? No spacers needed with them?
Thanks for all the info.
You'd need to use the wheel spacers with the Adair tracks unless Tim provides you with his wheels with a deep offset. I'd say use 21" Carlisle AT101 tires just like the factory does with Adair tracks and you'll be in good shape. You can get the tires brand new here:
Carlisle - AT 101 Chevron
Give Tim a call about those wheels when you get your tracks and I'm sure he'll be able to set you up with what you need."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Definitely order with bearing cages,good idea for any track system and a real pain to install after the fact. I believe RI factors the track package price with bearing cages installed normally. The Adair track systems that I have seen videos of are certainly a fantastic system but I don't believe they are a match for winter operation in snow or on wet/dry glare ice that the factory system is. The factory system can climb hills on wet smooth ice sounding just like suction cups .
I hope we are right about the RI tracks, JP. I'm going for a moonlight New Years Eve cruise tonight in the 2 1/2 feet of snow we just got total in two back to back storms. First time I heard the name "Camoplast" does that indicate a manufacturer or the style?
Originally posted by smithder View PostSo we have a new Max IV on order with the 29 HP Kawasaki and 26" tires. We are covered in the power department. If we wanted to later add Adair tracks all we would need is smaller tires and the tracks right? What size tires do the Adair tracks fit? No spacers needed with them?
Keith.sigpic
