OK so I recently acquired a Big Max 2 full machine but it was in bad shape and will be more work than it worth to get running and operational, got it for a whopping price of free so not I have plenty of spare parts for mine. Want to make a meat wagon/ atv trailer out of it but not like argo's that is only the lower tub leaving not much space. I want to add a top to gain space and a lid to keep it all dry. Has anyone here done this? I was thinking of cutting the upper tub and getting it somewhat flat so that I had good walls to support it all without a lot of additional weight. pics would be great. Thanks guys
BIG MAX 2 meat wagon help
make sure you tie the "lid" into the frame (maybe with posts??) so you can put gas cans and gear that needs to be handy on top.Alaska floating atvs group on face book. Fixing help and trail rides!!!!!
ATV = Alaska Terain Vehicle
oh yeah I planned on that. Just trying to figure the best way to add the lip. the argo trailers are just a lower tub with a floor and hitch, not much room from the floor to the top, and max has the slope from the back to front. I would double the room if I could use upper and lower tub by cutting the upper out to give me double the depth. but I want to keep the strength from the two parts and make a smooth finish. I have only seen one pic from the manual section of the set up. I will use a reinforced plate to frame for the tongue mount and also beef up the rear hitch mount so I can pull two (moose in AK get big) also will slotting the hitch so it fill pivot vertically.
