Frozen (with ice) Throttle Cable Fix
  • Frozen (with ice) Throttle Cable Fix
    Hey All,
    OK, so after washing the Max IV this Fall, the throttle cable got a bit of water in it. I have the the cable heater, but it was taking 15-20 mins to thaw. I decided to fix it. I simply disconnected it from the throttle handle, pried up the little rubber end boot and poured in some gas line anti-freeze (99.9% Isopropyl Alcohol, Heet brand). Voila, even at 0 degrees, it is not frozen at all - no need to wait.
    I had in the past removed the cable and lubed it and dried it, but it always froze again in the winter. Easy and fast fix.
    Great tip!
    Thanks
      also, if you take a small rubber hose that is 2 feet long, hose clamp it down to the throttle cable for an air tight seal, put the Heet (isapropal alchahol) maybe 3 or 4 table spoons, then use an air gun to blow it through, you will have no problems. This is gaurenteed fairbanks ak -20 F technology
      ATV = Alaska Terain Vehicle
        I've heard of some people putting actual antifreeze for a radiator in their throttle cable with good results as well.
          Another way is for me to drink the alcohol (Jack Daniels) and then I don't care about the frozen throttle cable.
            Here in bavaria whe build our trottle cable with a better tube. in the inside of this tube is PTFE ( Teflon) . With this and a PTFE Dry Lube never have a problem with frozen Gas Trottle.On the Top and the End we do a Rubber . This rubber looks like a accordion.
            Here in the alps mutch people, also me,dont like to stop biking in the deep winter. A trottle cable heater nobody nows here. The rubber looks like thes on this website.
            Silicone Rubber Bellows for sale - Price,China Manufacturer,Supplier 1575675
              Wow, and I thought I was the first with this idea!
