Does anyone know what a new max iv tub would cost new? Mine sat in storage for about 10 years and the body/tub have sagged and the tires have rub thru the fender wells, I was wondering if I could just replace tub and that would put things back where they should be.
Max IV Tub
If you call Recreatives, they might a couple "seconds" sitting around. These are lower tubs that have minor scratches on them, but are totally functional. Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511 The only problem is that it'd be expensive to ship it."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
You could also heat the body with an electric heat gun and use some boards to square it up, for penetrations take some sheet aluminum or steel and pop rivet and silicone in. Thats a cheap approach to it. JP's idea is good as well, but with the cost of a 2nd, then shipping, its sometimes good to work with what you have. That also opens the door to body mods such as raising the fender height.Originally posted by anotheramature View PostDoes anyone know what a new max iv tub would cost new? Mine sat in storage for about 10 years and the body/tub have sagged and the tires have rub thru the fender wells, I was wondering if I could just replace tub and that would put things back where they should be.
