I'm in the process of restoring a 1994 max 4 and need information on proper cable routing location. The original cable was removed by previous owner. Is the cable routed to the frame?
The cable runs in between the upper and lower tub along the left side of the machine. It turns the corner and comes out the upper body through a small hole behind where the engine sits.
Drew, you're thinking of the choke cable routing. The throttle cable routing goes down the right lateral, and along the inner frame rail and it snakes up right where the battery is and up to the engine.
Oops, your right I was thinking of the choke. Too much going on, my posts are starting to get sloppy.
