how maney batts in that max .
duel battery
1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
R.I.P sage rogers 4 11 09 .
ohok cool . our new one will not have a recoil start so i want pleanty of battery power . got to have tunes and winchrobbie .
Last edited by rdr; 03-16-2008, 05:07 PM.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
using solenoid to connect 2 batteries
This is really useful. Now here is a question that shows just how much of a newbie I am: do you keep the original intermittent solenoid in place and ADD the continous power solenoid (placing it between the 2 batteries), or does the continous power solenoid REPLACE the intermittent one? Also, if it replaces the intermittent solenoid, do you need a switch?
I did it now engine won't start
Hi All,
My black ground wire from the switch touched my battery lead on the solenoid while I was putting things together - making sure things were ok before adding a continuous power solenoid for dual battery. Snap, crackle and pop...smoke started coming up from the engine block. Since then, the engine won't start, either with the switch or the pull cord.
Any ideas?
What about a different battery
I was looking at Dual use Marine batteries as they have enough cranking power to start the machine, and enough deep-cycle reserve capacity to run an electric outboard motor for a half a day. I prefer this idea to 2 batteries in order to keep the weight down06 Bigfoot
battery switch
in the world of power boats, this is the type of switch usually installed.
West Marine: 350A Compact Battery Switches Product Display
usually a trickle charger to keep them from discharging. batteries do not like to live in a discharged condition. if the device is stored isolated from electrics, one of those little photovoltiac cells that plug into the cigar(utility?) lighter work.
