How many hours should i put on the max before i change the trans oil? Also is the easiest thing to do to take the T-20 out to change it? Looks like its going to be a booger tring to get to the drain plug.
Max2 T-20
I like to recommend the first change at 50 HR. I found a vacume oil changer at Lowes that works great. Item #: 141690 | Model #: 2005. just pick up a piece of 1/4 inch O.D. ridgid plastic tubing and use that to suck the oil out the top (fill) plug. Push the tube straight down till it hits a stop in the case, this gets all but about 1/2 oz. of oil out. refill with 28oz. ATF and 4 oz. positrack additive.
