First off i'd like to say thank you guys on here because I have read tons of your guys posts to give me ideas on my machine and helped me fix some problems on mine also. But still leaves me with some questions that I havent seen answered yet. My first question is. When driving my Max II even going straight I get a slight popping noise, and gets louder when turning. seems somewhere between the center and the front. First it was on the right side only (my right while sitting in the machine) and now seems that it is doing it on the left also but not as loud. I replaced all Bearings and bushings in the machine when I bought it about 7 months ago. All axles seem aligned correctly. And since then I had an incident with a tree stump that was hiding cleverly beneath the brush that decided it wanted to flip me over.
The noise started shortly after that so I assumed it was the bearing on the front wheel that took the impact so I decided to change it but did not fix my problem. I will start with just this one question and see where it gets me. Thanks in advanced guys. Just want this machine in mint condition so I can start making it to some of your guys trail rides. Oh and by the way the machine is mid to late 90's. round headlight style but with solid axles with bushings not bearings on the inside. Thanks again
