ok guys time to spend some money doing overhaul on my max going to get new motor new clutches new belt was thinking about the 23hp can anyone give me some advice were to get good prices and the best stuff to get tired of the little 14 need more power
max ii overhaul
For the clutches and belt either order from your local dealer, the factory or call Roy at Quality Drive Quality Drive Systems
First off, don't ever deal with Richard Clark/Route 6x6. And like Mike said, call Quality Drive systems, your local Max dealer, Recreatives, try ebay for Briggs Vanguard engine deals, or Recreatives Max Clutches | ATV Parts | MFG Supply ."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
That's a good deal. Make sure it has a 1" keyed shaft. This way you can use the less expensive 1" Comet clutch. The 1-1/8" clutch is more expensive.Originally posted by slim8108 View PostThanks guy for the info found new vanguard 23hp on ebay for 1200"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
3x QDS! Call Roy He can set up the clutches and has belts etc.. Great guy to deal. All he'll need some specs, center to center distance etc. Bolt on and go and you'll know its set up correct right from the start."Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
