Has any one tried the 25" Argo avenger tires on a max2 & what mods do you need to make to stuff them on...how did they perform .would like to know before dropping big $$$ on them.THANK YOU!
bigger tires on max2
Make sure it's the 25x12x9 Rawhide III for the Max II, not the 25x11.50x9. The 11.50 wide size is actually taller and won't fit on a Max II."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Also, if you will use the search, there is a lot of detailed information on this topic. Here's one thread for example: http://www.6x6world.com/forums/max-a...es-max-ii.html
i was looking at a avenger with both the rawhide3 and the argo tires on it yesterday, the argo tire is definitely bigger. i'll see if i can get gil to measure them both as i'm currently one handed for a month or two. unless obsessed can do it first.sigpic
This was my inspiration for creating the bigfoot. I originally wanted the Argo tires for water speed, but the price tag and the reports of poor mudding ability changed my mind.Originally posted by Mike View PostAlso, if you will use the search, there is a lot of detailed information on this topic. Here's one thread for example: http://www.6x6world.com/forums/max-a...es-max-ii.html
Here's the tire size info: http://www.6x6world.com/forums/tire-...html#post95939Originally posted by ARGOJIM View Posti was looking at a avenger with both the rawhide3 and the argo tires on it yesterday, the argo tire is definitely bigger. i'll see if i can get gil to measure them both as i'm currently one handed for a month or two. unless obsessed can do it first.
Here's some pictures and video.......WOW, that is fast in the water! If I only played in the water more, I'd be back to considering a set.
BTW, the 22" and 24" tires will fit the stock 8" rims unlike the 25" that require a 9" rim.
On the down side, they are not as wide as the 25"
MaxFrontier
