My 1985 fiero's fuel pump went out yesterday-My question is will my max 2 be able to tow the fiero from my front yard over the lawn to the backyard to my garage.Its just a normal lawn no hills.I have a 1 7/8" ball on my max and its mounted to the frame.That little fiero is to heavy to push on the grass,my girlfriend and I tried to push it and I felt like a real wuss after moving it about 10 feet then quitting!
max 2 tow a fiero?
The fiero has a v6-my max is actually a scrambler body with a max frame and a 13hp engine-the 6x6 is extremely light-I have a 1968 sears ss12 garden tractor that seems heavier duty than the 6x6-I have a 20 foot well craft boat that the garden tractor can pull-but the front end gets lifted off the ground and I cant steer due to the hitch weight-The max 2 frame just seems kind of cheesy the way the hitch is attached to the frame with 5/16 bolts so I figured I would ask before I burned up a t20 band or ripped the frame up.I love my 6x6 its just very light-I can lift the front end up by hand and I can lift the rear up by hand-The fiero I am not able to do this and it seems like there is nothing on this website that states a clear towing capability-everything I have read states 900 lb towing which seems very light-I cant find any info on tongue weight.Thanks for the replies I will give it a shot.
You'll spin the tires before you break anything....specially on grass...but a good rule of thumb is if the motors revving....and tires ain't spinning....and your not moving....stop cause something has to give at that point. Plus with a 13hp your gonna have a hard time snapping something."You've got to stand for something, or you'll fall for anything"
"Theres the right way to do things, the wrong way to things, and the way everyone else does it"
Max II, 22 Inch Rawhides, Winch, 16hp Briggs Vanguard...My First AATV...
I must make a fancy sign of this and post it at work. One day people might learn.Originally posted by dzg View PostYou'll spin the tires before you break anything....specially on grass...but a good rule of thumb is if the motors revving....and tires ain't spinning....and your not moving....stop cause something has to give at that point. Plus with a 13hp your gonna have a hard time snapping something.
