I noticed my turning radius is not equal. The inner circumference of left hand dougnut measures about 6.5 feet and a right hand turn measures 8.5 feet. The 6.5 feels pretty tight and I don't think I could get better than that. During normal driving it feels fine, but I suspect something is wrong. Facing the T-20, I adjusted the upper left hand plunger and turned the bolt clockwise about 3 full turns. From what I understand, this would have tightened up the brake band. This had no effect. I measured the outer diameter of the tires and they are all equal. Thoughts?
Max IV turning radius
Very good observation! A lot of folks might overlook this. It's an easy fix too.Originally posted by msafi65 View PostJust worked on one that didnt turn properly and found a missing axle tube bolt. one tire was rolling when that side was locked up. Just watch the tires in a locked turn."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
You guys are good. I found my right rear axle bolt sheared off in the tub. I replaced the grade 3 bolt with a grade 8. Both left and right turns feel pretty tight now.Originally posted by msafi65 View PostJust worked on one that didnt turn properly and found a missing axle tube bolt. one tire was rolling when that side was locked up. Just watch the tires in a locked turn.
But will use of a stronger bolt cause something else to break on the drivetrain? Is use of a grade 3 bolt an intentional fail-safe design?
A nifty solution to those broken axle-tube bolts, which you probably already know, is to drill through the tube and axle to add a second bolt at each wheel position. -Suggest you wait to do that when you're already doing serious repairs/mods and have it well dis-assembled. It's not the kind of job you'll be able to do leaning over the edge of the body and using a hand drill.
Added a second bolt to each wheel on my old MAX IV back in 2010 and haven't had a broken bolt since. (Knock on wood!) Before that, it was a continuing problem, especially on the left rear wheel, which is the most difficult one to reach. (Why is that always the case?)Last edited by Wobbly; 06-10-2013, 07:58 PM.
