I hadn't given a thought to 6x6s since I was about 10 years old and someone down the street had 3 of them parked in the driveway. Then I stumbled across one on Craigslist and it all came back. My 9 year old has been wanting to build some sort of all terrain thing maybe using one of his older brother's old power wheelchairs as a base and I thought a 6x6 could fill that urge and be a fun project.
So after missing a couple of good deals and passing on a few not so good ones, I got a max IV project for us to work on. It has no engine but the rest of it looks to be all there and not too beat up. Based on the serial number compared to others here, I'm guessing its a 94 or 95 model.
I'll be asking here for advice and help from time to time, I'm sure.
First order of business will be pressure washing the inside and freeing up all of the linkages. All chains are rusted solid. There is a coating of dried gunky grass covering the bottom, but the frame does not seem badly rusted.
After that I'm not sure. Am I better off taking it all apart and replacing bearings and sandblasting and either painting or powder coating frame and other parts, or just trying to use it and letting what breaks be my guide? I lean toward toward the rebuild, just to avoid being stranded somewhere.
I have good mechanical skills and access to a full workshop and machine shop to use. I'm looking to wind up with a solid, reliable fun machine. Not an extreme off roader or a racer.
For an engine, I'm thinking a 4 stroke of between 16 and 20 HP depending on what I can find. For starters, the shift levers on the transmission are stuck. I got one side to move and turning the clutch put force on the rusted chains, I couldn't get the other side to budge. Is this a free up and hope for the best, or should I open the transmission, clean it out and at least measure the bands?
Any advice on how to proceed would be appreciated.
Here is a picture of it on the trailer when I bought it.
