If I belive my outter bearing is bad is it nessery to change the inner bearing also ? The outter bearing isn't really that bad but is does leak water, So i'm going to change it.
2003 Max II 850T (inner bearings & outer bearings)
Not it may not be necessary, but its a good idea to just do them all at the same time. Also, water leaking is not necessarily a sign of a bad bearing, it's a sign of bad seals which can result in bad bearings. If you jack the machine off the ground and shake the tire and get little to no movements, the bearings are good for now, but if it wobbles all over the place, they have gone bad.l like to buy stuff and no I don't do payments!
