Hello. I seen an ad in the Anchorage Craigslist for a used Max II that requires reassembly.
The guy says the parts come with the machine, including jack shaft bushings.
Do all Max IIs use bushings or can I use bearings?
He doesn't know the year of the Max, nor does he know if it uses splined axles.
I think he may have to get a better look.
Anyhoo.... Can pinned axles be substitute by splined axles with no mods?
What are some pointers I should be aware of when buying a used Max?
He did say the transmission is tight, no holes in the tub, tires are in good shape.
Thank you.
Thank you.
