Bent Frame
  • Bent Frame
    Been searching forum. I think my ride up in the mountains of west va last weekend was a little rough. Tires are touching the body pretty good. The tires look like they have a bad camber issue........Has any one ever straightend a frame while still in tub...Any Ideas?
    I want to make it to busco this weekend...
    Check your bearings. When they go, the axles will look angled and can make the tires rub the tub.
      Everything is fresh in this machine, check your body for sag as it may be an illusion.
      If not it's going to be hard to straighten, perhaps strapping or chaining all axles down and jacking on center frame rails only? Be careful as it could be made worse.
