What kind of grease works best to seal the bearings and keep the water out? And hoe often do you grease them? I was looking at the waterproof amsoil grease but I want your guys' opionions first
best grease for outer bearings
hi ,
lithium /calcium combination grease
[Donnot use lithium or either calcium individually ,both are below average when done this way ]
This grease can be a little hard to find
Shell S2 v220AC
The A is for Aquius [water operation suitable ]
The other grease is alluminum complex grease ,far better than lithium
[purge the old grease b4 use or flush with new grease ]
Found in some marine greases
marine STA lube , crc marine grease water wash out less than 5 %
Dupont marine grease with Teflon water washout less than 1%
OMega underwater grease used in industry only apparently very very good but very expensive no tech info
tomoLast edited by Tomo; 10-15-2013, 09:13 PM.
