Got the WWII surplus light Friday, then worked over the dash. Now, it's complete. Replaced that intermittent key switch too.
And, turned on. I can't figure out what the weird reflection is by the volt meter. I probably should've painted the dash panel with flat black instead of the gloss engine paint I had on hand. Oh well.
An edge view to better show the aircraft surplus "push to test" light.
I also drilled the dash and mounted a nifty eBay gimbal type pitch/tilt meter. It was only $6.49. I sawed the mounting base off, then used silicone to mount it.
And, the old "meep meep" horn from my Yamaha road/dirt bike. I'd replaced that with a "real" horn nabbed from my Jeep which was replaced with air horns. I wanted the bike to sound like a large sedan coming at someone, and it worked. (I used it to commute to work for a couple of summers before selling it) The "meep" horn is pretty loud mounted right there in the open.
I finished a piece of 2x2 pine with linseed oil and bolted it to the engine cover with stainless bolts. That now keeps the storage box from migrating around. So, it's ready for the sand dunes. All I need now is some decent weather. Now that it runs great and idles, (Rebuilt carb) I'll have to take it back out into the lagoon again, and get used to being on water. There are sand dunes at Moses Lake which includes sand islands in a huge reservoir and swamp areas. It's about 90 minutes drive away. I'm ready now!!
