2014-02-14_13.23.04.jpgSo the Max IV I recently bought that was only supposed to need "1" chain replaced and the old famous "carb cleaning" has become much more than that. Being a perfectionist I have pulled the engine and stand (to get to the gearbox chain), removed all the rusted chains, pulled the crudded up fuel tank that was preventing fuel from getting to the carb. And I found that only 3 tensioners were installed, the 2 at the gearbox and 1 between the rear and middle axle.
After reading a lot of articles on here and the disassembling my rig I have a few questions for the Max vets on here.
1. The previous owner broke the plastic throttle where the cable slip fits but told me the cable was froze up. Can just the plastic lever be replaced or do I have to buy the entire throttle lever assembly? I can't really see how the plastic could be repaired or reused.
2. The machine sat out in the weather with gunk clogging the open drains so water pooled in the belly and completely ruined the chains. Should I at this point check/replace the inner bearings? Not sure how to check the bearings for serviceability while installed.
3. The frame rails are rusted but not to the point where I can see holes. I'm thinking I should probably pull the entire frame out of the tub and clean it up and repaint. From what I can see this looks like it could be a buttload of work. Or should I just spray some rust converting primer on it and move out smartly?
4. Lastly, as previously mentioned only 3 of the 6 tensioners were installed. The tensioners that are installed are all the same and I assume original, all are 18 tooth. I've found that TSC has solid #50 idlers 15 tooth with bearings that I could make work. I think the 15 tooth idlers will work for the chain tensioners between the axles but I'm not sure that they can be used for the 2 tensioners at the gearbox. So my question is this, do I have to use the stock 18 tooth idlers at the gearbox or could I use one of the 15 tooth idlers that I've found at TSC?
Just to caveat, I'm pretty handy but don't have a full blown shop and the ability to manufacture parts as needed like a lot of guys do on here. So, I'm trying to do things right without all the cool tools and machines. Basically I have to use off the shelf stuff to get do what I need to do, I have very little fabrication capability.
Sooooo, what say ye?
And of course thanks in advance for all the pearls of wisdom that I know will be shared
