I'm new to all of this I just got an old rim with a new kohler command 25hp engine and a rebuilt t-20 my major question is my top speed is only 12mph is this right?
Top Speed of Max IV / RIM
That's the one that has been for sale on Pittsburgh Craigslist for a while, right? That should move about twice that speed. He probably has the incorrect clutch spring in the driven clutch (2 stroke spring because it probably originally had a G50B Chaparral 2 stroke in it) and the belt is probably way too lose."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
First thing to check is belt tension. Should be just able to pull the belt up and get about 1/16 inch clearance on inside hub( at crankshaft ) or engine clutch. Looser than that will give pour performance. Also full throttle with the belt on in reverse should be about 4100 rpm
Originally posted by msafi65 View PostAlso full throttle with the belt on in reverse should be about 4100 rpm
I believe msafi65 meant to write "4100 rpm in Neutral"sigpic
Congrats on your puchase H. You have to check back every day at least 4 times once you have joined our cult. Its a rule. Then you will buy more machines until you can't fit cars in your garage. Oh wait, thats sounds like me. Anyways good luck. Later Mike
