Less than a year ago I discovered that both set screws had sheared the tips on them on the center drive sprockets on my Max II. After a fairly difficult repair I replaced them , lock-tited them etc. Last night when backing in the garage I could determine that definitely the set screw sheared on the left side allowing the sprocket to slide enough to hit the frame when rotating. At least this time I know what it is right off last time I nearly gave up before identifying the trouble.
It only breaks the set screws when the tracks are on for winter usage . The machine is ten years old,never sheared a set screw until last year . It is actually potentially a major over haul to repair these, last time on this same side I had to pull the axle as the set screw had to be drilled out and re-tapped. I did a complete bearing replacement about 3-4 years ago,this failure has been since that. I'm puzzled in theory there shouldn't be much strain on the set screw side to side but under torque I guess there still would be.
I can't figure what I am doing wrong but would like to move beyond this. Any ideas? Possibly the older hollow axles with bolt-thru on the sprockets or the new desogn with the snap ring retention system would serve better.
