Just bought a 98 max 4 with 20 horse kola. Seems slow. My argo would fly by this. What is the normal speed for this machine? Gona check the clutches tomorrow. This has no winch but does have the mounting plate. There is no support to the mount. Just a backing plate. I would think it would damage the shell with that kind of force. Any suggestions? Thanks
Max 4 speed and winch mount
What Argo did you have? Just wondering if it was a 2 stroke. Also, what size tires do you have on your Max IV? If you have the 26" tires you should be able to easily go 20-22mph at ~ 4000 RPM. I would start by checking your belt tension and then your clutch engagement like you mentioned. As for the winch mount, the backing plate will work fine as it is.
I had an 04 Bigfoot with 18 horse. It would cruise at 28mph. If I had to guess the max was around 15mph. My max has 26 inch tires. This is my first experience with a max 4. So not really sure what to expect. My buddys max 2 is crazy fast. Guess I was hoping for 25mph on a good trail. I'm really surprised that the backing plate is all the support they use for the winch. Seems like it would be a lot of force on the body but I'm sure you guys know your stuff so ill put one ASAP. I am really excited to take the family out riding in max! My boy will love it and I feel really safe will rops and seat belts.
The Max should be at least as fast, most likely faster than an Argo. I bet your belt is worn/stretched, or too loose. That's the most common cause for a vehicle going too slow like that."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
