The easiest fix would be to drill two shallow recesses for the set screws to sit in, use knurled point set screws with blue locktite on them. I don't believe the factory ever used set screw only bearings, all I have actually looked at had eccentric collared bearings.
If the inner frame rail is flat where your issue is you could try to install a mounted bearing there as well to aid in axle retention.
