Need help. Hey guys I put my motor back in my max II and did the ole test run befor putting belt back on and, surprise both clutches are in closed position on engine and t-20. How do you get these in the open positions so there is enough slack to reinstall belt. They both leave the belt sitting on top of the pullys
Help messed up belt install
Well I tried putting the belt around it and pulled. But bell did not close. While idling then giving it gas I can see it flexing inside the bell like it should. But bell doesn't close and open pulley. It had worked perfect just took motor a loose install chain adjuster. On left side Didn't fool with anything else. It had set for over a month thu while I worked out of town
Pulled my friend backwards on his Honda Forman
Well got my belt back on last night, also had put 2 new rear adjusters and two new chains on rear. And also my gator tires are new. Test run today. Went up some creek banks my 4 wheeler friends couldn't. also it came down to a tug of war between me and a Forman 4x4. He didn't stand a chance we tightend up the chain I started moving forward with him a little and his 4x4 was hopping up and down. So I gave my max a little more gas walked away with him. Successful day. Lol
tomo, thanks for your reply. I didn't do a good job of explaining my problem. My primary clutch, mounted on the engine output shaft, is open all the time. It's open wider than the belt. By revving the engine the clutch plates close enough to squeeze the belt a little. Enough for it to drive the transmission and vehicle slowly, like in low gear. I believe it's up on the weights, like someone said above, but I need a clearer explanation of how to get it back in place so the plates will close back together.
