I bought this from a guy who couldn't get the engine started. So he decided to pour gasoline through the top cover hole into the carb. Well it caught on fire and they through dirt on it to get the fire out. The carb, plug wires, wiring, etc is crispy. It runs ok but won't idle. After reading the forum I made the decision to replace the motor with a Bandolero while I have it apart. You can see in one of the pictures the right chain hit the frame. is this a problem? Otherwise it looks pretty unmolested and the wear parts don't look like it has many hours. The chain adjusters are still in the factory settings. The chains are "O" ring chains and look like still in good condition just need to be cleaned.
I rotated all six tires once I got the chains off. The left rear bearing makes a faint grinding noise. Should I replace all bearings while I have it apart? Any comments from the pictures? Thanks!
