after doing some rough riding, I discovered I crack my tub near my middle axel on the bottom. After some research I found the best way to fix it was to use plastic from A coffee container or milk jug. I heated the area with a heat gun then put the plastic over the crack and heated and melted it together. I will fill the tub with water and see if it leaks wish me luck.
