Max IV chain maintainance
  • Max IV chain maintainance
    I've looked on this board and on utube and been unable to find one. What i'm looking for is a video that shows the proper technique for tensioning the chains for a MAX IV. I've seen the one Mike did for the max 2, it's a great video but does not cover the max iv. Can anyone direct me to one or send me a link please?
    The basic premise is the same as far as how tight you want the chains. The only difference is the actual tensioners themselves. Loosen the bolt that goes through the sprocket. Then press down on the sprocket until the chain is at the proper tension. Hold there and tighten bolt. Two people can do it very easily. With one person, you have to get a little more creative. I usually use a 2x2 piece of wood to hold tension down on the sprocket while I tighten the nut/bolt.
      Ok, i can do that. How does your answer relate to the chains on the t-20 itself (primary chains?)? It would be different, right?
        Right, for the chains going from the T20 to the rear sprockets, that idler is held in place by four flat pieces of steel. Two short ones coming from the frame up to the sprocket and two long ones going from the sprocket back to the rear of the frame. You should start by loosening the nut/bolt that goes through the center of the sprocket. Next, loosen the two bolts below the sprocket that hold the short pieces of flat steel in place. Finally, at the rear of the frame, loosen the inside nut, that is the one towards the front of the machine. Now you are ready to tighten the chain.
        Tighten the chain by tightening the nut at the rear of the machine. Once the chain is tight, reverse the process. Tighten the inside nut at the rear of the frame. Then tighten the remaining three nuts/bolts.
        Hope that made sense. :don'tknow:
          Thanks for the help Mike
            This needs a video. I think I know what you mean but a video would help a lot. Perhaps someday someone will do one.
              The chain adjusters for the Max4 rear as Mike described are a real piece of work. Its a three or four hand chore that sometimes necessitates the pulling of the engine cradle. You don't usually have to pull it, but more often than not I end up doing it.
              As a work around I've been working on a set of manual adjusters for the Max4 for some time. Hopefully this year I'll finalize them, and may even come up with an automatic adjuster. Stay tuned.
                Noel... Can we assume you will market a kit for this?
                  I look for many ways to market products and earn a living, if the thing works, then maybe. Right now its still in the CAD stage for an automatic adjuster, the manual adjuster should be something that someone can recreate.
                    not sure why you would need to move engine cradle two 3/4inch wrenches and about 15mins and all chains are good to go? am i doing it wrong
                    1996 MAX IV ,KUBOTA DIESEL
                    MAX II 30HP Bandolero
                      it takes you that long, i can do that in 3 min
                        all 6 adjusters in 3mins are you speed Gonzalez lol
                          My "panic mechanic" (wife) and I are going to adjust the rear axle chains tomorrow. And possibly the trans chains. It seems it ought to be easier to remove the rear seat first. Anyhoo... Diving in, wish you speed mechanics were up here.
                            Max iv chains video please!!!
                            I'm not sure why the max iv chain adjustment thread was closed that i started? Either way i agree totally that
                            I re-installed my rebuilt tranny and drove it for about an hour on a test drive near the house. Everything seems to go well...then i go to turn a 180 (to the right) in the trail and break the driver side chain on the tranny. (is that called the primary chain?) Fractured 5 links in the process and broke it completly apart in another place.
                            The only thing that i noticed before that was that it took more effort (not bad, just a little) to pull the latterals back. Figured it needed a small adjustment when i got home. Yea, guess i should have stopped and done it then. However the problem with that is that i was pretty sure it should have gotten more slack during the drive, not gotten tighter.
                            New guys like myself would greatly appreciate someone taking the time to make a video that is in depth enough. Say you install the tranny...go from there and show the proper process of adjusting the chains from that point.
                              I agree. I'm one of those guys that learn best by watching someone do things. Although I can and do learn from reading about things I still favor watching. Sometimes I can't "picture" what is being told (reading). And viewing someone do it in person or vid helps a lot.
