I installed new bearings and flanges on my max ii. I purchased these from Richards relics. The inner flange I installed with the lip of the flange facing towards the frame. I should of looked at my other max before installing because that one is installed with the inner flange lip facing out away from the frame. My bearings are moving freely. Is this OK or should I change them ? Note: I do not have an inner bearing. It's an older max
max ii bearing flange
Check out the How to Replace Your ATVs Bearings article in our How-To section. It has plenty of photos and a video showing how they go.
Some of the early machines had 3 flanges, the inner most flange inside the tub was more for frame support than anything, if it's not hitting don't fret it.sigpic
I put the one with the grease sert on the outside and the one without on the inside with the outer lip towards the Frame I noticed on one of them when I pump grease into it it comes out on the outside of the tub. On another one the grease comes out on the inside?
Originally posted by Dano1877 View PostI put the one with the grease sert on the outside and the one without on the inside with the outer lip towards the Frame I noticed on one of them when I pump grease into it it comes out on the outside of the tub. On another one the grease comes out on the inside?
Did you use the strip caulk against the body on the inner (non greasable) flange? did you line the grease hole up with the zerk? Next silly question, are the carraige bolts sitting flush in the frame?sigpic
max ii repairs
Originally posted by Dano1877 View PostI watched the how to video on this site which I should have before I used Richards how to before and his pics and directions are lacking. Needless to say I'm redoing all of them. Thanks for the help Mike and jim
The overall consensus is to avoid Richard's Relics due to higher prices and/or inferior parts. He's considered a last resort sort of thing.
Now, I will say I did buy Ago parts from him simply because he had the items snd shipped to northern Alaska. A lot of other places won't ship to a PO Box. Items were very good, prices comparable to other places.
Matt O owns Recreatives Industries/ MuddOx and had factory parts available.Stand for the Flag. Kneel for the Cross.
I bout a few stickers from mat and one came bent and the shipping cost was high. The dude sent them in a box when they probably could of got sent in an envelope what are the price diferences? On let's say an axle? And are they the same product or different ? Thanks guys
