My front tires on my Max IV seem to be rubbing. Is it bearings or tub sag?
Max IV tire rubbing
Max IV tire rubbing
Is the body sagging? I'm not the resident expert mind you: jack up the offending side and see if there is up and down, side to side play when you shake the tires. It thats not an issue (and the body is sagging on that side) then just jack up the side thats sagging and leave it in the hot sun for a day and night. Then take off the jack the next morning.
I just looked in your gallery and you have the newer k-lock wheels.Originally posted by sgtlane04901 View PostI will try 5 psi thank you all
By all means, do not run 5 PSI. Get a low pressure tire gauge and run a true 2 PSI. There is a HUGE difference in ride quality and since you have the k-lock wheels, there is no reason not to lower the pressure that much. You just have to make sure you have a low pressure gauge, otherwise the reading won't be accurate.
HI
A 2 1/2 inch or 4 inch 0-15 psi tire gage is the what u need . Most tires that are 26 12 12 4 ply or smaller 8/9 inch will be max operation pressure 5 psi .
Fitting pressure is another story .
If u run an older tire above the 5psi or use excessive fitting pressure they will go an egg shape or be really pointy compared to a younger tire .The polyester/nylon cords [these form the tire ply rating ] inside the tire break .
tomo
